Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
175 Fragen Alle anzeigen
How to remove keys off of a MacBook air
i want to make sure before removing any keys by just pulling them off that there isn't any adhesive or anything i could damage by just pulling the keys off of the key board
the reason that im removing the keys is because of a large amount sugar got under the keys on the left side of the keyboard
thanks in advance
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Why are you removing the KeyCaps?
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
I'm removing them to clean out a large amount of sugar that was spilled on the keyboard and got under the keys :C
von
@timtomissus Without being able to give a proper method to remove the keycaps efficiently, I can say that they are only held on by tiny plastic clips on butterfly hinges. These clips break very often, so be gentle.
von
@cashewclay can you still put the key back on if the clip breaks?
von
@timtomissus Each key cap has two clips and two tabs, as pictured quite well here: https://www.laptop-parts.com/blog/MacBoo...
Check out where the clips are before prying, just so you know exactly where to pry and minimize the chance of breaking clips.
Edit: my partner just informed me that you may have scissor switches, not butterfly keys.
von
@cashewclay would it be the same protocol if the mac had scissor switches?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
timtom77 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 153
