Zum Hauptinhalt wechseln
Ein konvertierbares 15-Zoll-Notebook mit Touchscreen. Modellnummer: 80V50010US.
Bluetooth devices failing to stay connected
Paired Bluetooth devices fail to maintain connection, resulting in audio that drops in & out, mouse connections that spontaneously stop, and keyboard inputs that fail to go through; all while the "Bluetooth & devices" page insists the devices are Connected, and Device Manager insists the Drivers are up to date. Trying to determine if this is a hardware issue, and if so, how would I repair it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Switch your wifi to 5ghtz
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
This is the Intel Model 8265NGW Dual Band Wireless-AC chip. Upon further inspection, it was noticed that the white cable, going into AUX 1, was not fully snapped on, and was being roughly held in place by a sticky piece of foam covering. Upon applying pressure until it was fully snapped on, drastic improvements to audio to almost-perfect were noticed; this will be further tested with Google Meets sessions & possibly Zoom before being considered fully fixed.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Hi @g3g0ry,
Are there WiFi problems as well?
If so perhaps it may be a loose antenna connection.
The WiFi and BT use the same antennas and are on the same WLAN/BT card inserted into the motherboard..
Bewertung 1
5 Kommentare:
No WiFi problems, which definitely makes it all the weirder. As a test yesterday, I pulled up lofi hip hop radio - beats to relax/study to, paired & connected my G435 via Bluetooth, and let it play for around fifteen minutes; the internet connection remained consistent throughout, but the audio cut in and out randomly, without any interruption to the stream itself. When I connect the G435 via dongle, I get no problems.
von
@g3g0ry
Try running the Lenovo hardware diagnostics troubleshooter and see if it shows anything. Click on Network > Bluetooth.
von
@jayeff I think I may have cracked this, thanks to the hardware booklet you linked to in the other Lenovo problem I working on (re: touchscreen not working & glitching, for posterity); turns out, the Aux 1 (white) cable on the Intel Model 8265NGW dual band wireless adapter wasn't fully "snapped on" (never seen a snap-on cable before) - in fact it was basically being roughly held in place by a piece of foam. After actually pressing it back into position (until it "snapped" into place) and putting on another YouTube radio stream for fifteen minutes, I heard maybe 1 or 2 VERY minor hiccups, indicating drastic improvement. We'll see how it pans out for work tomorrow.
von
@g3g0ry
Most if not all WiFi/BT antenna cables in laptops and mobile phones have the "coax" type connector and just plug in, either to a removable card or direct onto a systemboard, unless the antennas need to be soldered directly onto the board.
von
The more you know! Thank you!
von
Check for wireless interference from Wi-Fi or USB 3.0 devices. Restart Bluetooth Support Service (services.msc). Try a different USB port or Bluetooth adapter. Reinstall drivers via Device Manager. Update BIOS and chipset drivers. If issues persist, test on another PC to confirm if it’s a hardware failure.
Bewertung 0
Antwort hinzufügen
GregH wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 732
