Zum Hauptinhalt wechseln
Support für die dritte Generation des Chrysler Town & Country aus den Modelljahren 1996–2000.
No power to radio, windows, wipers
I have a 1999 dodge caravan sport and it just recently started to have a problem. When I crack the van up it sounds like a small pop sound under the dash and I have no power to the wipers, windows, and radio, and the air then switches to the defrost automatically. However, when I turn the van engine off the accessories then come back to life, but they go back out again when I start the motor.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I immediately suspect a bad ground. Most vehicles have a grounding block that will commonly ground many accessories. It will usually have a metal strap looking cable coming off of it that connected to the motor, trans or frame.
Hopefully someone here can tell you where to find the grounding straps on a 99 caravan. Unfortunately I have no idea.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Robert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 363
