Zum Hauptinhalt wechseln
Repair information and troubleshooting for the Dell Latitude 7480, a 14" business-class laptop computer.
Why is my battery light turn off when I connect the charger.
Whenever I connect a charger to the laptop. The laptop battery light turns on for 3 sec and then turns off again. Then I disconnect the charger and again connect it with some force. then the light turns on and goes off again and after 2 sec, it turns on again, and the laptop starts charging and shows the time remaining to complete charging. Otherwise when the light goes off after 3 sec laptop shows (plugged in). I don't know when this is happening. Sometimes it takes 3 to 4 times (disconnect and connect) to start charging.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Whenever i plug my cord into the powerpoint the light turns on, to indicate that it works but whenever i let it dangle or plug it into my laptop, it turns off and doesnt cahrge my leptop
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
There may be a problem with the power connector port (aka DC-In jack) in the laptop.
Sometimes the inner +ve conductor of the jack can fail intermittently causing no power to be received by the motherboard from the charger.
Here's the owner manual for the laptop. Go to p.28 to view the procedure to remove /replace the DC in card to gain access to the cable plug and just disconnect the power port cable plug from the card and then connect the charger to the power port.
Use a voltmeter to measure the voltage on the red and black wires of the plug. If there is 19V DC when measured at the port's cable plug, then gently move the charger's plug up and down and side to side (not in and out) inside the power port to see if the voltage remains constant or comes and goes.
If it comes and goes the jack is faulty and will have to be replaced as it cannot be repaired.
Search online for 8GJM9 to find suppliers that suit you best.
War diese Antwort hilfreich?
Bewertung 1
Charge port could be damaged, especially if you have to use force.
Bewertung 0
1 Kommentar:
I’ve got the same issue and a new DC in port has not resolved it. Any ideas?
von
Antwort hinzufügen
Awais Jutt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 4,325
