Is M2 SSD Temperature normal?
After performing OS upgrade for this beauty i noticed some high Temps. Later i performed some general benchmarks to doublecheck and the SSD heat up to 77 degree. Is that normal due M2 slot location, since its near GPU and CPU? Both of it were even below 50 so im unsure why still newish SSD (original HP) runs that hot. I do use crystal disk info as tool.
Should i move over to classic Sata SSD?
Ist dies eine gute Frage?
5 Kommentare
Are the 77 degrees in Fahrenheit or Celsius?
von Jacob Mehnert
@toddk80 we do need to know if you are using Celsius or Fahrenheit. Normal operating temps for your SSD would be between 30ºC to 65ºC or 86ºF to 149ºF
von oldturkey03
77 degrees in Celsius, however it was due benchmark.
On normal work more between 52-62ish.
von Todd
@toddk80 sounds to me like your SSD is within specs.
von oldturkey03
Ok was just curious if any other owner has same temps and if this being critical.
Thanks
von Todd
