What would cause a fault code electric solenoid issue causing no forw
No forward gears only reverse
Ist dies eine gute Frage?
If your 1997-2004 Ford F-150 is experiencing a fault code electric solenoid issue causing no forward gears, only reverse, it is likely that there is an issue with the transmission. The electric solenoids are responsible for controlling the flow of transmission fluid within the transmission, which in turn allows the transmission to shift into different gears.
Some possible causes for this issue could include:
In order to properly diagnose and repair the issue, it is recommended that you take your Ford F-150 to a qualified mechanic or transmission specialist. They will be able to perform a thorough inspection of the transmission and related components to determine the root cause of the issue, and recommend the appropriate repair or replacement solution.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 29
