My machine îs seeyng that my servis door îs open but îs closed properl
My door îs closed ok i check the microswiht and it's working ok but the error îs steel there and i wa
Ist dies eine gute Frage?
Based on the information provided, it appears that your Saeco Intelia HD8752 coffee machine is indicating that the service door is open even though it is closed properly. Here are a few suggestions you could try to troubleshoot the issue:
I hope this helps resolve the issue with your Saeco Intelia HD8752 coffee machine.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 110
3 Kommentare
Hi,
Did you test it with an Ohmmeter to see if it was electrically OK when it was operated or just that it physically operated and released OK?
von jayeff
Not yet but i Will test IT TODAY to see If it's working but i tocht the cables whit the conectori and it's stil reads the error
von Raul Pirvulet
@Raul Pirvulet
Touching the cables doesn't mean that the contacts in the switch aren't dirty or corroded. You need to test them electrically.
All you've proved is that the wires aren't loose or dry joint, not the switch itself
von jayeff
