Zum Hauptinhalt wechseln
Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
After testing, it appears to be a dead capacitor. Thank You!
von
@Joseph Galaska No problem, hope you get it working.
von
Antwort hinzufügen
Joseph Galaska wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 761
