Zum Hauptinhalt wechseln
Die kabellosen BeatsX In-Ear-Kopfhörer wurden 2017 von Beats by Dre entworfen und hergestellt.
Won’t turn on and can’t reset
My Beats X won’t turn in and I can not reset it
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
From what I learned it's all obviously caused by a faulty battery.
I actually found this guide on reviving a battery in Beats X.
If that doesn't work - here's a guide on replacing a battery and those guys offer a place to buy a new battery as well.
War diese Antwort hilfreich?
Bewertung 1
Basically your battery is dead and needs to be replaced. I had the same issue with my Beats X in-ear headphones.
My Beats X were also 5 years old and I hadn't used them in more than six months, which probably made things worse and allowed the Li-ion battery to discharge completely.
I tried these options before confirming the battery was dead and needed to be replaced:
  1. I charged my Beats X overnight for more than 12 hours.
  2. I attempted a factory hard reset by plugging in the lightning cable to the charging port and then holding down the power button + volume down button at the same time, for 10 seconds or longer.
There was NO LED flashing after the factory reset. I removed the lightning charging cable and holding down the power button didn't start up my Beats X. After plugging in the lightning charging cable, the LED would flash white/ red/ white/ red and then stay on white.
Helpful Resources & Guides:
  • This place sells new aftermarket replacement batteries($14.49 each); and offers a good written replacement guide.
I hope this helps!
Bewertung 1
Antwort hinzufügen
Glenn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 71
Insgesamt: 2,414
