Zum Hauptinhalt wechseln
Dryer shuts off and will not continue.
Dryer shuts off and will not continue drying. It can be shut off, reset and restarted, but will not continue drying. If you walk away and come back later the dryer is running and drying clothes.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
It possible either your vent pipe is stopped up not allowing the heat to escape the dryer or there are some heat safety switches in the dryer that could either be bad or weak. Both instances will cause the dryer to shut off until it cools and then turn back on with out anyone being around it.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Tried all suggestions, replaced all sensors, plus belt and rollers for drum. still does same thing starts drying clothes then stops midway. will not start back up, but if you walk away it will start back up and complete cycle.
von
Tried all suggestions, replaced all sensors, plus belt and rollers for drum. still does samething starts drying clothes then stops midway. will not start back up, but if you walk away it will start back up and complete cycle.
Bewertung 0
3 Kommentare:
Can you post a picture of the dryer so I can have a better idea of exactly what we are working on please?
von
Maytag Bravo MEDX700XL0.
von
Antwort hinzufügen
R. Von Deane wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 110
