Zum Hauptinhalt wechseln
m5884 dc internal broken -- how to change it
hallo... i've to change the dc connector...+ pole broken
is possible to have a guide... it is different from newer model...
i've the ac connector covered by a floor of circuit....
It's my first mac (bought in 2000) ... i would to my daughter the opportunity to play a little bit with him ...
I'm writing from switzerland and now i have my second mac... a MacBook Pro model 2009 .....
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Ifixit doesn't have the manual for this repair, but if you look here: PowerBook G4 Titanium Mercury you'll see various other rapairs that will lead you in the right direction. This repair PowerBook G4 Titanium Mercury Logic Board Replacement will most likely suit your needs.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
thank you from Switzerland ....
i'll check ....
von
No Problem. Good Luck.
von
Antwort hinzufügen
fausto wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,841
