power comes on click click then No picture?
Why does the power come on, then click click and the green light goes off and then no power?
Ist dies eine gute Frage?
This unit is equipped with a power failure detector function and will turn your unit of to protect from further damage. This model apparently has some trouble with bad capacitors on the power board. Check for bulging, leaking capacitors. You should also check this question for more info on this issue. Hope this helps to get you started. Good Luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,225
