Brother MFC-L2710DW updated FW blocks third party toner. Downgrade?
Hello,
I found out today that one of the latest firmware updates of the Brother MFC-L2710DW has blocked an otherwise perfectly functioning and still almost full (90%) toner cartridge. I don't print very often, but this is really annoying.
The message on the display is that the toner is exhausted, so the continue mode that should force the printer to use it anyway is not working.
To add to this, the user interface tells me to use only original Brother consumables "to get optimal results", but even if I am perfectly fine with the third party toner (honestly I see no difference) it seems I can't use it. By searching on google I found that some users have been downgrading Brother printers as they are encountering the same issue on different models.
Is there anybody that might help with this problem?
I would want to either downgrade the firmware or finding a way to bypass the block.
Thanks.
Ist dies eine gute Frage?
