Is there a fuse there?
Where is located the fuse and how can I approach it?
Ist dies eine gute Frage?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
War diese Antwort hilfreich?
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 286
There are numerous fuses. Can you describe the symptoms?
von Jim
The printer does not show any sign of life after an unclear power interruption.
von tvarozna
