My vacuum is making a very loud noise when I run it
Is this a filter issue?
Ist dies eine gute Frage?
Hi
When you say a loud noise that could mean a couple different things
A loud whining noise when you turn the vaccum off could indicate that the motor bearings are failing,they will need replacing
If it’s making a really really loud noise constantly that sounds a bit like a drill that’s stripping a screw that’s also usually the motor bearings
If it’s giving a sound off that sounds like it’s speeding up then you hear a sound that sounds like pressure being released, that is a blockage
If it’s making a whistling noise check the hose and the seals around the cyclone
And if it’s making a loud BANG! every couple seconds that usually mean the carbon brushes have failed and will need replacing
I would check the filters just in case anything is blocking them as a blocked filter can cause debris to gather in the tubes and heavy items can make a rattling noise when that happens
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
You may be right about it being a filter issue. The first thing I would do is check spinning parts, tubes, and filter for any stuck debris/clogs.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 195
