Zum Hauptinhalt wechseln
The Kodak Easyshare Z981 features a 3.0 inch bright LCD screen and 26x optical zoom with a 26mm wide-angle lens. The 14 megapixel resolution makes for vivid prints up to 30x40 inches.
The batteries corroded in the camera . How do I successfully clean th
How do I clean the inside battery compartment? The batteries corroded . I removed the bad batteries and need to clean the connectors
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I’m assuming the leaking battery didn’t get into the body of the camera. If it did, you’ll want to open the body and clean it out using the same method below except DON’T use a screwdriver to get the corrosion off. Stick with a plastic brush. For the battery compartment:
  1. Vacuum what you can out while you are using a small screwdriver to scrape the battery ends gently. Tap the camera body gently to knock the corrosion out
  2. Use a Q Tip dipped in some rubbing alcohol and dab at the corrosion using a new Q Tip end every minute or so.
  3. You’ll have to note if you removed the corrosion from the metal tabs (or springs) in the camera. If you didn’t, a small flat blade screwdriver should be used to clean it off and repeat #2 until the metal tabs are clean.
  4. As long as you can see metal (it’s ok if it is copper looking beneath the chrome), a fresh battery should conduct power fine.
Hope this helps to save that camera.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Marilyn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 36
Insgesamt: 1,629
