iMac won't boot up
Won't boot up. White screen fan noise for a few seconds, there's a crack then it shuts down
Ist dies eine gute Frage?
Sounds like a power issue. Did you have a lightning storm or high winds in the area? What can happen is a power surge zaps your system power supply and it can also damage your logic board
Time to inspect things to see if you ca spot the damage. Follow this guide to check the Power Supply iMac Intel 27" EMC 2429 Netzteil austauschen you’ll need to inspect the capacitors and power transistors for swelling or burnt. The main logic board will likewise need to be pulled to inspect it fully as well. Pickup from Step 14 in this guide [iMac Intel 27" EMC 2429 zweites Laufwerk (SSD oder HDD) installieren
Let us know what you discover!
Anleitung
Schwierigkeitsgrad:
Mittel
20 - 30 minutes
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 3 hours
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 28
