Zum Hauptinhalt wechseln
Verwendet einen kleineren Kühlkörper und einen vom Nutzer abschraubbaren Standfuß.
Front USB and USB-C ports not working
I took apart my PS5 to deep clean it, wasn't the first time I've done this. But when I put everything back together, I tested the USB and USB-C ports, and they were not working. The backports were fully functional. Any help?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You may have connected something wrong, missed a connection, or messed up the port
War diese Antwort hilfreich?
Bewertung 2
The flex ribbon connector that connects the usb A/C board to the main board is very fragile. Inspect the cables gold pins to see if they are damaged, also inspect the gold pins inside the connector as they can also get mangled.
Bewertung 0
Antwort hinzufügen
Odiin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 36
Insgesamt: 1,551
