Samsung QLED White/Washed out screen - Main Board or LED Driver Board?
Samsung QLED QN75Q8FNBFXZA
Hello!
Not exactly sure how to describe the issue with this tv, but the screen is completely washed out - picture displays and issue is independent of input as the problem is also present on built in smart tv menus. Other ways to describe the issue is greyscale or slightly negative picture?
I've found similar issues via research online but with older tvs that have a T-con board. My tv does not have a replaceable T-con board.
I've taken the tv apart and have performed a handful of tests but it hasn't gotten me any closer to a root cause.
Would appreciate any thoughts from the pros as to whether they think a replacement of the LED Driver Board or Main Board could fix the issue?
Images of issue attached. Thank you!
Additional images of internals:
Update - Close up of Main Board per request:
Ist dies eine gute Frage?
2 Kommentare
@q1iqizbn7xzhhae Any chance of an update if the replacement board worked or was it a panel issue ? I have the same problem and the eBay seller said the same thing..that it is a screen issue and not to bother ordering a replacement board for my Samsung 65" TV.
von emmbeeheavy
@q1iqizbn7xzhhae Any chance of an update on if you tried replacing the main board or was it a screen/panel issue ?
I have the exact same problem and the eBay seller has also messaged me saying that its likely a screen issue and not to bother replacing the board. The board is $50 so i might as well give it a shot but curious to know what happened in this this case since this is the closest post I could find to my problem :)
von emmbeeheavy
