Zum Hauptinhalt wechseln
Die US-Version der sechsten Generation des Sonata wurde auf der Los Angeles Auto Show 2009 vorgestellt, der Verkaufsstart für das Modelljahr 2011 erfolgte im Jahr 2010. Für den US-Markt bot die sechste Generation des Sonata einen 2,4-Liter-Vierzylindermotor mit Direkteinspritzung.
How can I change the water pump?
The water pump needs to be changed. What would be the best method of doing this?
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
@mahdirahim61663 what exact year and engine size is it?
von
They there, I edited your question a little bit just to be a bit more accurate to what I believe you are asking. Can I ask what specifically is wrong with your car's water pump?
von
@satpindersingh unlikely that it even has a butter pump. you are not giving us enough information. Make, Model, year, engine size, what pump, why do you think it is that pump, what have you checked?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@mahdirahim61663 this should work for you
Removal and Installation
Loosen the drain plug, and then drain the engine coolant. Remove the radiator cap to drain with speed.
Remove the drive belt (A) after turning the drive belt tensioner (B) counterclockwise.
Remove the water pump pulley (A).
  • Tightening torque :
  • 7.8 ~ 9.8 N.m (0.8 ~ 1.0 kgf.m, 5.8~ 7.2 lb-ft)
Remove the water pump (A) with the gasket.
  • 18.6 ~ 23.5 N.m (1.9 ~ 2.4 kgf.m, 13.7 ~ 17.4 lb-ft)
ULEV : Remove the exhaust manifold heat protector (A).
  • 7.8 ~ 11.8 N.m (0.8 ~ 1.2 kgf.m, 5.8 ~ 8.7 lb-ft)
SULEV : Using the SST (09392-2H100) (A), remove the front oxygen sensor (B) and the remove the exhaust manifold heat protector (C).
  • Tightening torque
  • Oxygen sensor:
  • 39.2~ 49.0 N.m (4.0 ~ 5.0 kgf.m, 28.9 ~ 36.2 lb-ft)
  • Heat protector bolts:
Remove the water pump housing (A) with the gasket and the water inlet pipe (B).
  • Bolt (C) : 9.8 ~ 11.8 N.m (1.0 ~ 1.2 kgf.m, 7.2 ~ 8.7 lb-ft)
  • Bolt (D, E) : 18.6 ~ 23.5 N.m (1.9 ~ 2.4 kgf.m, 13.7 ~ 17.4 lb-ft)
Installation is reverse order of removal with a new water pump gasket.
Fill the engine coolant.
Start the engine and check for leaks.
Recheck the coolant level.
from here
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
mahdi rahimi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 24
Letzte 30 Tage: 93
Insgesamt: 3,031
