Zum Hauptinhalt wechseln
Das größte und teuerste Smartphone, das Apple am 20. September 2019 angekündigt hat, verfügt über ein 6,5" OLED-Display, ein Kamerasystem mit drei Linsen und eine deutlich verbesserte Akkulaufzeit. Es ist der Nachfolger des iPhone XS Max.
20 Fragen Alle anzeigen
My phone is turning off suddenly every 3/4 minutes
I phone 11 pro max problem
My phone is turning off suddenly every 3/4 minutes, then it turns on automatically. Important battery message shows after turning on the mobile. And the mobile is charging at 1%, and no battery health is showing. Again the battery health of the phone is showing for some time, everything looks normal. Then after running the phone again for a while the phone turns off and on again and the Battery important message is showing.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
@mehrajsalfi Yeah, here's the key line in your panic log:
Missing sensor(s): TG0B TG0V
According to the kernel panic Wiki:
TG0V and TG0B are a function of the battery.
So yeah, it's time for a new battery, my friend. This guide will show you how to go about replacing it.
iPhone XS Akku tauschen
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Yup. This is a dead ringer for a battery problem to me. Right down to the weird battery data.
von
@mehrajsalfi, If your phone is rebooting every three minutes then it's almost certainly due to a bad sensor, in this case it's most likely in the battery. Go read the information in @flannelist's excellent Kernel Panic Wiki article and use it to retrieve your panic logs, then come back here and paste the first page or so into an answer so we can confirm the source of your reboots.
iPhone Kernel Panics - iFixit
It sounds like you've got a bad connection going to your battery, as the battery health coming and going is not normal, and you shouldn't be getting the non-genuine battery warning if you still have the original battery or the battery was replaced by Apple, but we can confirm once we see the panic log.
Bewertung 1
9 Kommentare:
i cant paste the panic because it was too long to paste
von
von
@mehrajsalfi Just the first part is usually sufficient; just paste whatever will fit into a comment or else you can paste it all into a separate answer.
von
@dadibrokeit Thanks for your help , sir
von
4 weitere Kommentare anzeigen
From my own experience, this is most likely a "Reset Counter" and "Panic Full" error. This is a hardware error that comes from shorted parts on the main iPhone. However, to be able to know exactly, you must have professional knowledge as well as a full range of tools to measure the pulse, otherwise you will need help from technicians.
Bewertung 0
If the iPhone randomly restarts then this will capture the panic data that you can find as a panic log-on ( Setting/privacy and Security/Analytics &improvement/Analytics data ). This will help to find the faults that I have done by this in my iPhone.Post comment below with log data.
Bewertung 0
1 Kommentar:
{"bug_type":"210","timestamp":"2023-12-23 17:19:03.00 -0500""os_version":"iPhone
OS 17.1.2 (21B101)" "roots_installed":0,"incident_id"-"4A4C0EE9-0A25-4936-B228-
C3A757506CA5"}
"build" : "iPhone OS 17.1.2 (21B101)"
"product": "iPhone15,3"
"socid": "8120"
"socRevision": him",
"incident" : "4A4COEE9-0A25-4936-B228-C3A757506CA5",
"crashReporterKey": "8f1ffd7d702c9dec6390940d13cb0b5568ba2564"
"kernel": "Darwin Kernel Version 23.1.0: Tue Oct 10 02:21:50 PDT 2023;
root:xnu-10002.42.9-2V/RELEASE_ARM64_T8120"
"date": "2023-12-23 17:19:03.86 -0500"
"panicString": "panic(cpu 1 caller Oxfffffff0680eb1dc): SMC PANIC - ASSERTION
FAILED: target/d74V/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10)
140\nS.sensor array 0 - 4 is 0x0, 0x140000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0|n|n
- Misc(2) OUTBOX1 not ready|nASSERTION FAILED: target d74target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 140\nS.sensor array
I’m having the same issue. Here’s my panic log. Can you tell me what this might be from?
von
Antwort hinzufügen
Mehraj salfi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 68
Insgesamt: 4,155
