Zum Hauptinhalt wechseln
2.3L 4cyl or 3.0L V6, 6th Generation
428 Fragen Alle anzeigen
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
That is voltage to the coil
von
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
Bewertung 0
Antwort hinzufügen
Michael Leonard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 224
