Zum Hauptinhalt wechseln
Veröffentlicht im November 2020. Der Mac Mini nutzt Apple's M1 SoC mit einer 8-Kerne CPU und einer 8-Kerne GPU. (Model Axxxx/EMCxxxx)
I need help with my Mac Mini
Well my Mac Mini was slow. So I formated it. When I was creating a login for the computer, the energy fell, I was like “oh okay then I will wait it to return” then after it returned it was like if I already set it up. I said “oh okay I’ll just put the password that I chosen” it did not work. Then I tried to reset it from my iCloud but It did not work it seems that it’s not in my iCloud but it’s appearing there, so I’m stuck with a Mac Mini that has a password witch is not the one that I have chosen and my iCloud can’t reset the password. If anyone can help before I bring it to an thecnical assistance I’ll be grateful
Thanks!
Atualizar (04/16/23)
I finally got it unlocked but now I have another problem.
It’s in Portuguese because I’m from Brazil. So it’s now saying “the version of macOS in the disk selected needs to be reinstalled, Use the recuperation tool to reinstall macOS or select another disk to initializate”
Then there is two buttons the first one “recuperation” and the other one “disk initiation”
Atualizar (04/17/23)
Thank you guys so much for help, today I’ll bring the Mac Mini to an Apple Store to see if they can fix it, again thank you so much for the help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Ouch! Did you buy this system new or used?
Dig out your paperwork as you may need it
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
It’s new, it’s actually my old Mac Mini now I have the M2 Mac Mini
von
Sure I’ll find it somewhere
von
@eugenioaragao - Hopefully you can get to an Apple Store and it’s still covered under warranty. Some countries have Two years others only one.
von
I just turned it off and on again and that happened
von
@eugenioaragao - Your system shouldn’t need reformatting or need a fresh macOS. Something is off here.
von
The picture you added in your update indicates it doesn't recognize an attached keyboard and/or mouse. You may need to connect them with a USB cable for the mac to recognize them the first time. But it seems like you're making progress.
Bewertung 1
1 Kommentar:
I hope I get it running again I’m pretty worried as it’s an expensive computer, my son said if I don’t get it running he will bring it to the Apple Store tomorrow to see if they can fix it up.
von
Antwort hinzufügen
Eugênio Aragão wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 39
Insgesamt: 370
