Zum Hauptinhalt wechseln
Das Gaming-Notebook Asus ROG Strix GL702VS ist ein leichtes Notebook, das speziell für Spiele entwickelt wurde. Es verwendet einen i7-Prozessor und eine mobile Grafikkarte vom Typ 1070.
Asus ROG GL502VSK Battery Replacement
Hi,
I've got a Asus ROG GL502VSK laptop which its battery is completely dead. I could not find an exact battery for this model and I was wondering if the Asus ROG Strix Battery which is available on this site, is compatible with my model and fits inside the chassis of my GL502VSK
This is the link to the available battery:
Thanks in advance
Replace a 4950 mAh battery compatible with Asus ROG Strix laptops. 76 Watt Hours. 15.2 Volts (V). Part #C41N1541, C41PP91, 0B200-02070000, 0B200-02070200, 0B200-02070300 Bild
Produkt
$59.99
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@pouriyajamshidi best thing to do, would be to contact Customer support and see what they tell you. You can contact them by various means as listed here https://help.ifixit.com/category/133-con...
I did check the compatibility for this battery and it does NOT look like it will work. Your ASUS needs a C41N1531 and the one listed is a C41N1541 Does not look like iFixit has those in stock. Again Customer service can definitely help you with that.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you for your time and help @oldturkey03
I will contact them and see what they say.
von
Antwort hinzufügen
Pouriya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 392
