Zum Hauptinhalt wechseln
Reparatur- und Demontageinformationen für die kabellose Logitech MX Master 2S Maus. Markteinführung 2017, zu identifizieren anhand der Modellnummer (M/N) M-R0066 oder der Teilenummer (P/N) 810-005769, 910-005138, 910-005137 oder 910-005131.
Right mouse click is not working
Hello,
my right mouse click suddenly stopped working on my MX Master 2s.
I tried following steps without any success:
1) Turned mouse on/off
2) Connected mouse via bluetooth dongle on other computer
3) Switched left/right mouse click via Windows settings
4) Bought a new original mouse click switch (from Omron) and replaced the old switch
-> After all my right mouse click is not working!
-> I now use a wired, old mouse and I have no problem at all with this.
Can you please help me?
Do you think it might be a hardware malfunction on the motherboard?
I mean I even replaced the switch.
Thanks,
Fabian
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Same issue here, is there any kit for solving this in Ifixt?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Have you checked the top "activator plate", of the mouse that activates the switch uppon depression of the mouse buttons? It sounds like the there may be a gouge in the "activator plate" which prevents the plate from making contact with the switch.
If you do see this I used some hot glue and filled in the gouge on an MX master 3 and its been going strong for a few months now. But you can also use other fillers to get better results.
War diese Antwort hilfreich?
Bewertung 2
Hello Zach,
thank for your help. Unfortunately this did not help. The "activator plate" has full contact to the switch. I even demounted the upper shell of the mouse and clicked on the switcc directly with my fingers. The right mouse click gives a nice snappy accoustical feedback, yes, but there is no response on my computer. In my opinion there must be a hardware malfunction on the motherboard.
Well I don't know what to now. Seems to be broken, unrepairable.
Bewertung 1
Antwort hinzufügen
Mr. Mouse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 52
Insgesamt: 4,945
