Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
Frage geschlossen
iPhone 4 screen display problem! Help needed!
I Broke my iPhone's front screen and the touch screen would not work... i repaired the screen with a new Digitizer/LCD screen replacement. After i finished putting the iPhone back together i powered it. The front screen came on but you could only see white light and not make out what was on the screen. I even got a call while it was like this i was somehow able to answer it by sliding my finger across the bottom of the touch screen how you would normally answer a call. so this mean the touch works but the display doesn't?
Does anyone have any suggestions to what might be the problem.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
How did you break it?Are you sure you ordered the right screen because there are different screens for the verizon and the at&t versions.Last try a hard rest if that does not work you could have gotten a faulty display.Other than that it would be a board issue
War diese Antwort hilfreich?
Bewertung 0
yes my Iphone only display problem but all thing write, camera and phone call all work but only display problem
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,717
