Zum Hauptinhalt wechseln
Reparaturanleitungen und Hilfestellungen für Glätteisen, auch Haarglätter genannt.
37 Fragen Alle anzeigen
What logic board component is this?
I am currently trying to resurrect a relatively expensive hair straightener. It is a Croc Infrared Titanium Ceramic 1.5-inch Flat Iron. Upon disassembly of the logic board, I did find an obvious burned out component. It does look like a resistor, but does not quite fit the pattern. It is 9.6mm in length, which would make it 1/2 watt. The part that does not look like a resistor are the ring markings. From what is left it looks like:
Black
Grey
third ring not clearly identifiable due to damage
Black
In the normal resistor world, the third ring would be the multiplier, the fourth the tolerance. Black is not an option for that. So anybody have an idea what I got here? Anybody have a flat iron apart to let me know what component I am looking at? I did try to find any schematic or diagram without success. Thanks for the help.
UPDATE
Any chance this could be a capacitor? I do know that some of them use ring markings as well.
Update Hope this is a better picture.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
11 Kommentare
http://www.csgnetwork.com/resistcolcalc.... you've probably looked at this site...
von
Thanks pollytintop. Yes I have, but it does not match anything I come up with.
von
I'd just walk in to the local shop and ask them to work it out..but then I'm a girl and they take pity on me! Seriously though it's worth a shot, our local repairman often has all sorts of parts and info that is far quicker to ask him than spend all day on line. When I look at your photo it looks like there are 3colour bands side by side..white/orange/yellow (odd! maybe it's white/space/yellow?) and possibly brown to the far right? As you say black gives 0 so.. I tried searching by length of the part/ceramic but there is no match that looks like your part.
von
Yes, it is the space that makes it look like extra rings. The part that makes me go hhhmmm is the placement of the rings. It is to symmetric on the body, unlike the resistors I have and the color black on both ends. I tried the store route, but had no luck at all. The salesperson just gave me a blank stare :-) I did contact the manufacturer (no answer yet) as well as Mouser and Digikey reps.....I guess will see. Thanks for your help....
von
Can we please get a closer picture of the component? When I try to blow this up it distorts. Also a picture of where it sits on the board, both side, could possibly help.
von
6 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You know, I would probably ignore the two black outer rings and only go the inner ones. The first looks brown to me, the last one looks white, but it's hard to tell from the image what the two middle ones are. I'll bet that's your ohm rating right there.
Also, look on the circuit board for another resistor that looks to have the same colors on it. Sometimes resistors come in pairs or groupings that are all the same ohm ratings.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
I have a CROC model BC-CR1. It has a 300 ohm resistor mounted on the opposite side of the digital LED box (that displays the errors). All my components look good, but I'm getting error 014 080. No idea what to do from here. I may try to contact a croc engineer, but the front desk is a pretty nasty firewall. $30-60 for repair, if unable to repair, $105 new. Yuk, they should let us have a go considering we're getting error codes. Not cool.
Bewertung 2
I have a need to see the original board it was on too. Please post a pic or email it to me so i can solve this riddle.
RIDDLE ME THIS
RIDDLE ME THAT
SEND ME A PIC
SO I CAN SEE WHAT THE !@#$ THAT IS..:(
Update
SIMPLY LOOK ON THE BOARD AND TRY TO IDENTIFY THE FORMULA BEING USED
IS IT IN A SERIAL OR PARALLEL FORM?
IS IT A RLC?
have you hooked it up to a DVM and seen any ohms? If so take the reading and match the colors that you do see. Are they closely related? Faded red looks brown..etc
Bewertung 1
2 Kommentare:
I sure did do that right from the start....got it resolved by getting it repaired through the manufacturer. Thanks for your help. I did not even realize that this question was still marked as unresolved
von
uggggg...we still don't know !!!! how can i sleep now?
von
Antwort hinzufügen
oldturkey03 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 4,464
