Zum Hauptinhalt wechseln
Whirlpool WTW4816FW or the Maytag Centennial washer MVWC415EW2.
Please help it fills then drains
Ok so yesterday my whirlpool washer worked fine today I noticed evertime I went down it would be on the wash stage not doing anything. So I started another cycle, it will fill and as soon as it's done it drains all the water,and seems to get stuck on drain mode for a min then the wash light pips on and it never does anything? Please help I'm totally stumped on this one.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hi @matthewmcc79269
Is it only the wash LED that comes on (is it blinking or is it steady?) or is there another LED on as well?
Here's the tech sheet for the washer.
Go to p.2 to see how to run the diagnostic tests - see Activating the service diagnostic test mode.
Once you have run the tests, decipher the error code as shown on p.3 - see Fault/Error Code Display Method
The error codes and their possible causes are shown from p.6 onwards.
Bit strange if there is only the wash LED blinking as there is no code pertaining to just the one LED except if it's a blinking fill/sensing LED and then it's an F0 E0 code - no fault
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matthew Mccartney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 630
