Zum Hauptinhalt wechseln
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
A.O. Smith water heater
Water heater makes a bubbling sound when reheating water in the tank
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Have you checked the operating instructions? Check your model at https://www.waterheatermanuals.com/ao-sm... and go to the troubleshooting sections to find the possible cause. Sometimes this is normal operation of the water heater, but it all depends on your model.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @d2icsw2fhjpsdob,
What is the model number of the water heater?
Sounds a though the thermostat may be faulty and not turning off the power to the heater when the water temperature has reached its upper limit or cut off point.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
heatherw319 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 189
