Instead of using the heat mat, can I use a heat gun...
Instead of using the heat mat, can I use a heat gun to take off the screen to get to the battery?
Ist dies eine gute Frage?
Yes you can. Apply heat around the edges then insert your opening tool freeing a bit of adhesive at a time. Then repeat until the screens off. Using some isopropyl alcohol as well will make the job a lot easier.
War diese Antwort hilfreich?
Do I need to use plastic picks? or can I use a spudger?
@nytryder26 I’d use a thin opening tool to make an opening then a thin piece of plastic. Plastic picks or a spudger might be too thick cracking the screen.
@strongbow Like this kit? iOpener
@strongbow Ok Ill check it out!
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 70
