Zum Hauptinhalt wechseln
The Samsung RF28HDEDT is a 36-inch French door refrigerator with a 27.8 cu. ft. total capacity, featuring a twin cooling system, LED lighting, external digital display and control, and a filtered ice maker. Its design includes a stainless steel finish, recessed handles, and hidden hinges.
Water Not Dispensing with Filter
I have a French Door with bottom freezer Samsung refrigerator. I have been experiencing issues with the water dispenser. It will dispense water fine without the filter in it; however, when I put an OEM filter in it, it will only dispense water for a bit before stopping. I have to take out the filter and put it back in to get the water to flow again for a brief period of time. Tried replacing the filter and still get the same result. Please help!
RF28HDEDTSR is the model number
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @vadad81
Could be a faulty water filter housing (supplier example only to show part and location0. Search online for DA97-08006D to find suppliers that suit you best.
Holds the water filter and connects it to the refrigerator's tubing system. Bild
Produkt
Samsung Assembly Case-Filter - DA97-08006D
$114.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
VADad81 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 29
Insgesamt: 267
