Zum Hauptinhalt wechseln
Dieses VR Headset kam am 28. Juni 2019 auf den Markt.
Headset completely lacking sound, Valve support says I can repair it?
Long story short, something about my HMD is wrong. Valve support won't help me much further than "you bought it from a 3rd party seller so we won't give you a new one but you can buy another one or go to iFixIt." The HMD does not produce sound. Not via the speakers nor the 3.5mm jack. The problem persists between computers, where windows says it is sending sound, but the headset does not receive it. What could I even replace to fix this problem? is it possible it's really just the cable and not the HMD?
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
I have the same problem. Not the cable problem because i have a spare new one and after switching them-nothing changed. Maybe changing the motherboard will help?
von
there is only 2 possible problem.
1. the cable connected to the speaker and 2. the speaker maybe out of solder or disconnected to its cord or set
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
SOUNDS to be the cable.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I ended up buying a new cable from steam. It got here in like a day so that's neat, and the sound even worked again for a couple days after I plugged it all in, and now I'm back to square one. So maybe it is the headset...
von
@cameronfowlks - Hmm @jayeff Lil' help here?
von
@beanman56
The OP says that Windows is sending audio so I assume that means that it is communicating with the headset OK i.e. it has detected it, installed drivers OK etc.
Don't know the headset but looking at an image of the cable it appears to be a USB-C connector at one end and a USB-C, USB3.0 and a 3.5mm socket at the other end
If audio is supplied via the cable and the cable has been replaced, check what the cable plugs into in the headset is not loose or damaged.
von
You've find a different tether than the valve index. It's power supply, display port, USB3.0 with a unique connector on the HMD side.
I guess I can pop open the headset to check out the connector though, thanks for the lead
von
Antwort hinzufügen
Cameron Fowlks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 36
Insgesamt: 1,574
