Zum Hauptinhalt wechseln
The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2 Fragen Alle anzeigen
Frage geschlossen
I can not turn on my nokia n95 8gb phone?
The screen shows the charging battery icon, the number keys lite up when pressed, battery has been charging for several hours, and does not show a full charge. The phone has been dorment for a long time, and im charging it through the usb adapter.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Joe, if your phone was not used for a good while, I would suggest that you change your battery. It is possible that you battery is past the point of its life expectancy and not accepting a charge. Good Luck
War diese Antwort hilfreich?
Bewertung 2
joe ur granda ma must have eat the batterey
Bewertung 1
my nokia n95 is power on after month but it is no power how iam on my mobile self
Bewertung 0
you should use 12 voltage of any charger to shock the battery of n95 for 8 second because i think it was just drain... if u have more problim you can call me baby,,, 09098016760
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 4,266
