Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
Where to get a replacement charging-port (USB-C) assembly?
I got a Galaxy Note8 phone, and lately I have had problems connecting the charging/data cable (tried several different ones). The connector seems like it's connected, but the connection is wonky (especially when trying to transfer data) and it falls out if you look at it wrong. When trying to charge, I often get the "not charging correctly" error. As I need to replace the battery (real!) soon anyway, I'd like to replace the charging-port assembly at the same time. I understand the jack-contact is modular and can be swapped over to the new assembly.
Anyway, may real question is where can I find/source a (preferably new) replacement charging port assembly? I couldn't find it for sale here (unlike the battery). I'd rather pay a bit more to get it from a reputable source, than from some dodgy dealer on Amazon or eBay... And I need it shipped to Europe.
Is this something iFixIt could get for me from a reputable source?
PS: In a pinch - if it was available from somewhere - I could change the actual USB-C port contact if it's at all possible... it wouldn't be the first time I soldered SMD components...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @koppe
Here's just one supplier that may be suitable.
If not search online for GH97-21078A GH97-21067A to find suppliers that suit you best.
If you wish to replace the board yourself, here's a video that may help.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Sounds more like your charge port is full of dirt and needs cleaned out. Use a needle to gently work round the bottom of the port keeping away from the centre post. Lift any dirt out, the do either end to remove any left over from the sides.
von
Antwort hinzufügen
Koppe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 146
