Zum Hauptinhalt wechseln
Das 13" MacBook Pro erschien im Mai 2020. Es ist ausgestattet mit einem Quad-Core Intel i5 oder i7 Prozessor der 8.Generation und Intel Iris Plus 645 integrierter Grafik. (Modell A2289/EMC3456 mit zwei Thunderbolt 3 Anschlüssen)
20 Fragen Alle anzeigen
My device won’t charge
This time lasts year my device stopped being able to charge. I paid apple $600 to fix the problem. A year has passed and the problem has happened again. I plug in the device and it won’t charge. I was hoping to have this repaired for cheaper than $600 seeing as I’ll have to do it every year in perpetuity.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
have you tried different cables, different power adapters? does the power adapter and cable work with your other devices?
is it possible there's dust etc inside the port?
it's possible that all they did before was clean the port out with compressed air in a can or perhaps after disconnecting the battery to eliminate the risk of shorts may have used IPA to clean out the port carefully with something to probe it, if that is the cause then probably wanna invest in some plugs for the charging port, I have silicone ones for my devices and it's great for keeping dust and any accidental splashes from getting in the ports.
War diese Antwort hilfreich?
Bewertung 0
What did Apple tell you they replaced? As that might offer a clue on what has happened again.
As this model only offers one set of ports it’s not uncommon for the ports to breakdown from use MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board to replace it you need to remove the logic board. We don’t have a guide, but we do have a similar systems teardown Teardown des MacBook Pro (13 Zoll, 2019, 2 Thunderbolt Ports).
But to be sure I would use a USB-C power meter to see if power is even getting through.
Replace one of the thunderbolt connector boards from the left or right side of your laptop. Bild
Produkt
$14.99
Bewertung 0
Antwort hinzufügen
Robert Givens wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 175
