Only dries in timed dry mode
We have a gas Bravos XL that only dries in timed dry mode. It runs and sounds like it’s drying in all the other settings but the clothes are still wet. Any ideas? Thank you in advance.
Ist dies eine gute Frage?
Hi @matt35052
Don't know about gas dryers but here's the tech sheet for the dryer that may help.
Run the diagnostics as described by the sheet and check if any error codes are displayed.
Hopefully this is of some help.
War diese Antwort hilfreich?
If it dries in timed mode then the likely error will be F3E2 Moisture Sensor Indicates the moisture sensor strip is open or shorted.
Since timed mode does not use the moisture sensor and everything else works in timed mode.
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 50
Insgesamt: 458
