Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage der Logitech MX Master 3 kabellosen Maus. Sie wurde 2019 auf den Markt gebracht und ist durch die Modellnummern MR0077, 910-005692, 910-005620 oder 910-005647 gekennzeichnet.
Grey housing turns ugly very fast. Please support replacement Parts
The grey housing on the MX Master 3 looks amazing but turns yellowisch and ugly in just a few month with sweaty hands. The housing is probably one of the cheapest parts to manufacture.
Could you please support a change of the outer housing of the mice?
Ist dies eine gute Frage?
Bewertung 13
4 Kommentare:
Same mouse, same problem. This basically happens with any mouse that has a bit of a rubber surface.
von
I'd also buy a replacement upper housing if available.
von
If Logitech wants me to actually take their "repair, don't rebuy" posturing seriously, this is a must. My mouse functions perfectly, but the soft-touch rubber has degraded over the years and is sticky to the touch. Please support us replacing the shell. There are some floating around on ebay now, but they're 50$ per piece and without official instructions, which does not seem reasonable to me.
This will basically decide whether I keep buying Logitech products or say goodbye to fancy smooth scrolling and go to a company that lets me keep my electronics out of the landfill.
EDIT: That said, kudos for starting this repair initiative at all. Do this right and you'll have a lot of trust and recommendations from my end.
von
I have the same problem with the black one, but this material is indeed more skin-friendly.
von
Einen Kommentar hinzufügen
1 Antwort
I have the same problem with the black version, although this material is indeed more skin-friendly. Currently, there's no solution to this problem. I recently purchased the RAPOO MT760 Pro, which has a similar appearance to the MX Master 3. Its mold is very similar to the MX Master 3, but the casing uses a different material, so it doesn't have this problem.
https://www.reddit.com/r/MouseReview/com...
https://shop.rapoo.com/products/rapoo-mt...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
FusterCluck wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 51
Insgesamt: 634
