Why do I hear noise when I accelerate?
When I first start the car and I in drive, when I accelerate the car make loud noise that eventual dies down once the heats up?
Ist dies eine gute Frage?
That is a fairly vague description of the problem. If it goes away quickly, it may be the exhaust system. That expands quite a bit as it heats up and that expansion may provide clearance that the system doesn't have when it cool.
War diese Antwort hilfreich?
I have the same issue with my 14 Rogue. For years, mechanics have bee saying it was the loose heat shield and some would use the worm clamps, which eventually got too hot and fell off. I got under the car and saw the rattle was a thin piece of metal on the curve pipe between the engine and the honeycomb mesh 3 inch pipe. Get it at Advance Auto Parts. It s a 3 inch heavy duty exhaust clamp with 11 gauge saddle and reinforced ribs. Part #517300 by Nickson. $7 each. Buy 2, preferably 3. Noise is GONE!! Tried to paste photo of the exhaust, but having trouble .
Link for the photo described above for the 3" heavy duty exhaust clamp.
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 73
Insgesamt: 1,535
@moniquegoings what kind of noise? Sounds like ? Where in general do you think that noise comes from (side, rear, front, bottom)? Any check engine lights on? Anything unusual when you drive your Rogue (other than the noise)? What exact year is your Rogue?
von oldturkey03
Pressing gas pedal when start to drive. I already had my catalytic converter replace. Rumbling sound in the front.
von Monique Goings
It a Rogue 2015
von Monique Goings
@moniquegoings do you hear that noise only when your Rogue moves or is the noise there when you are stopped and the engine running?
von oldturkey03
I have the same problem when I accelerate the car make a noise like something is getting on the tire and the car vibrates a little, the car starts doing it after a code p0841 appears, my is a 2019 rogue
von Ian santos
1 weiteren Kommentar anzeigen
