Zum Hauptinhalt wechseln
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
Why is my car idling too fast?
Engine idling too fast have checked hoses and air intake.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@kevinmason could be an issue with the throttle position sensor. Check for a cracked or leaking air intake. If you start your car, let it idle and spray some WD40 (or starter fluid) sensible around the intake, you will find a leak. Once the engine idles even higher when it gets those vapors, you know you have a leak. Of course, you can't rule out a computer malfunction etc. I suggest you get your Ford scanned and see if the OBD pops some codes.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kevin Mason wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 139
