The Toyota Yaris is a subcompact car produced by Toyota since 1999.
Between 1999 and 2005, some markets received the same vehicles under the Toyota Echo name. Toyota has used the "Yaris" and "Echo" names on the export version of several different Japanese-market models.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
@letlhogono92979 there just isn't enough information. We need a bigger story :-)
What exact model and year? Engine size? transmission ( automatic/manual)? so it goes to 80 (mph/km/h?) and then what happens? How does it idle? How does it run? What have you checked?
It's a Runx 1.5 , automatic 1NZ engine,2005 model, when it reaches 80 it decreases the speed and start having a loud rough idle when I press the accelerator,fuel consumption is very high,I changed the oil,the sparkplugs,air/oil filter and I even replaced the petrol pump still no difference
You can never give to much information :-))
von oldturkey03
von letlhogonolo Bolokwe
