Zum Hauptinhalt wechseln
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
Check engine light on
Catalytic converter code I don't have $1000 dollars to spend on my car am a single mother w a disabled son I need help on the cheapest way I can fix it myself plzzz help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Ms. Ali,
I've had cat codes on my '99 Beetle, and it doesn't always mean a thousand dollar repair. Some of the codes can be alleviated by replacing the oxygen sensors that detect the functioning of the catalytic converter rather than replacing the cat itself. It's gone both ways on my bug; I got the codes to go away by replacing oxygen sensors, but eventually I ended up having to replace the cat itself. But even that doesn't have to cost so much; I bought an aftermarket cat from a reputable manufacturer - Magnaflow and Walker are both good brands - and had a shop weld the replacement in for far cheaper than $1000.
Specifically what code or codes are you getting on your car? What year is it? Is it a Turbo model?
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ms Ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 235
