Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
Richard, there are a lot of experts in a wide variety of subjects on here. What information are you looking for regarding your Traverse?
I know their entire power and drive trains are junk. Transmissions are known for failing catastrophically, and the water pumps are driven by the timing chain. So when the pump needs replacing, most shops won't do it unless you do the timing chain as well because you have access to it right then and there. What should be a job that costs a few hundred dollars now costs thousands. Skip to 13:22 https://www.youtube.com/watch?v=g5KxRIqD...
von Jerry Wheeler
von Jesse Hooton
