Zum Hauptinhalt wechseln
A rugged mobile workstation that is part of Lenovo's ThinkPad lineup released in 2014. Repairs and detailed information can be found here.
Why screen still dark
i have bought this used lap w541, it was working well, after 3 months its start to give dark screen, the problem is : when i press on the power on switch, the fan runs for a while then stopped and the screen still dark, after many tries it may start to work, sometimes does not wrok at all
if someone face this problem and know how to soleve it i well be very thankful for him
thanks in advance
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @ahmedamer17250
Sounds like the laptop is not passing POST (Power On Self test) on startup. Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Remove the main battery from the laptop.
c). Remove the RTC coin cell battery from the motherboard.
Here’s the hardware maintenance manual for the laptop. Go to the bottom of p.60 and p.69 to view the necessary pre-requisite steps and then the procedure to remove the battery pack and the RTC coin cell battery respectively.
When the coin cell battery is removed measure its voltage. If it is <2.6V DC replace it. The part number is 02K7078. If you search online using the part number only, you will find suppliers of the part.
d). Press and hold the laptop's Power on button for a full 30 seconds and then release it.
e.) Reconnect the RTC coin cell battery (or its replacement).
f). Re-assemble the laptop and reinsert the battery pack.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
thanks a lot, i will try these steps and hope to solve the problem
if it solved i will give feedback
von
Hi Jayeff
I've follow the same procedure you mentioned above, and after many trails assembly and disassembly all the lab parts, finally give the results you mentioned. Now I've left the lap working all the time and afraid off turning it off, so that it may stooped again.
what do you think
von
@ahmedamer17250
Did you replace the RTC battery with a new, fresh one?
If so then if the old RTC battery was low then hopefully the problem won't reoccur.
You got it working so why not have confidence that you can do it again ;-)
von
Alternative to a POST failure, the screen backlight may have failed. If you look very closely, very carefully at the screen can you see the screen contents? If so, the backlight or its power supply has failed. Most backlights are not expensive and not too hard to replace.
Another solution to a failed backlight is to use an external display. Of course, you lose the portability of the laptop.....
Bewertung 0
2 Kommentare:
Hi @eeandersen,
The question is why would the fan stop if it was a failed backlight?
Cheers
von
Just a helpful guess, easier to do than disassembling. Not all CPU fans run all the time, especially on a laptop where battery life is important.
von
Antwort hinzufügen
Ahmed Amer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 529
