Zum Hauptinhalt wechseln
Das kleinste iPhone 14 von Apple wurde am 9. September herausgebracht und verfügt über ein 6,1-Zoll-OLED-Display, ein fortschrittliches Dual-Kamerasystem mit 12 MP und eine Frontkamera mit Autofokus. Es ist der Nachfolger des iPhone 13.
9 Fragen Alle anzeigen
let my phone lay on charger( by accident)
Few days ago, I accidently put my iphone 14 on the laptop charger, which was moderately hot at that time as it was working (my friend was watching ytb while charging). I realised it trapped heat only a few minutes later. Would it cause any potential damage to the phone? Do I need to worry about it?
P/s: my phone is still working properly ever since, I am just lil bit pertrified :(
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @hoangnam81305,
No, you're okay. The thing is, when you read through most any of the repair instructions here on iFixit, virtually all of them involve applying heat to the phone; heat the back to loosen the adhesive, heat the front to loosen the adhesive, heat the flex cables; basically for anything that's glued down you will probably get told to heat it to get it off.
The applied heat can range from a hair dryer, an iOpener tool, a heating mat and even a heat gun. Given that most of these are capable of putting out much more heat than the laptop charger you're worried about, you're safe in assuming your phone is fine. As hot as you think it is, it really doesn't compare to the other heat sources I've mentioned. If the phone can survive those, a laptop charger isn't going to hurt it.
Hope this puts your mind to ease.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
thank you ! I appreciate it!
von
Antwort hinzufügen
Hoàng Nam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 96
