No spark cold starting
Vino 125 is hard to start cold it acts like no spark
Ist dies eine gute Frage?
If the motor turns over OK on starting and the fuel supply is OK then it seems as there is an ignition problem.
Metal contracts when it is cold and expands when it heats up.
It may be when cold there's a faulty electrical connection e.g. dry solder joint perhaps, that prevents the ignition circuit from operating correctly. Once it warms up the connection is good enough to maintain the circuit operation
Here's the service manual for the scooter that may help.
Go to p.7-10 (p.247 of 293 pdf numbering) to view the troubleshooting flowcharts for the ignition system.
I suggest that you do this when the engine is cold as you may not find anything when the engine is warm or even if the ambient temperature is warm and the scooter has just warmed up without being started.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 231
