The eighth generation model of the Passat was introduced in November 2014 in Continental Europe and in January 2015 in the United Kingdom as a four-door saloon and estate.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Hi @joedinatale,
What is the year model of the vehicle?
Does the vehicle have a key lock cylinder in the driver's door?
If so does the key insert OK into it?
If it doesn't it may be a faulty key.
If it does it may be a faulty ignition lock cylinder.
Have you got a spare key that you can try?
von jayeff
