Thermal Replacement Paste and Thermal Pad Size / Thinkness for Vram
I did thermal paste replacement for CPU & GPU with " Noctua NT-H2. Which seems be doing great. And, the thermal pad "ARCTIC TP-3 / 1.5mm on the VRam "
The System works fine till i start using " Youtube " only this one " Gpu 0 Diode " over heating like crazy and goes up to 109°C / 228.22°F" and as soon as i pause the video it drops quickly down. to normal temperature. While browsing i do not have any issues its completely normal temps. But is only this " Gpu 0 Diode " that does this.
" Apple iMac 27" A1419 5K Late 2014 Logic Board 820-5029-A w/ AMD R9 M295X 4GBApple iMac 27" A1419 5K Late 2014 Logic Board 820-5029-A w/ AMD R9 M295X 4GB "
Please advice
Update (06/13/23)
Hey Dan, Thank you for the quick Response
This is a " 4gb AMD Graphic Card " and about " GPU 0 Diode " where it sits on the board, Same here cannot figure it out. I did search a lot online, but no luck.
The board could be : " Apple iMac 27" A1419 5K Late 2014 Logic Board 820-5029-A w/ AMD R9 M295X 4GB "
another is the Thermal Pad too big in size on the Vram? Should i trim it smaller then try again?
just adding 2 images for more details. if required
Update (06/15/23)
Close Up of GPU
Update (07/13/23)
@danj - How about i Reflow or Reballing the GPU chip? You think that would help?
Ist dies eine gute Frage?
1 Kommentar
von Sam
