Zum Hauptinhalt wechseln
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 Fragen Alle anzeigen
Blank screen/No signal
Built a PC. Everything shows it is running. The screen is npt connecting to anything. I have tried different monitors and different setups, different hard drives. No BiOS or anything comes up.
ASUS Prime Z590-P WiFi motherboard
Intel Core i7 11700F processor
GTX PCIe 730 Graphics card
CORSAIR DDR4 16GB RAM
I have reset CMOS. I have taken everything out.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi @familyfun37946,
Is the 16GB memory, 2 modules i.e. 2 x 8GB or one 16GB module? Depending on number of memory modules have you installed them as per p.1-5 of the user manual?
The PC may not be passing POST (power on self test)
Try connecting a system speaker (example only) to the speaker pins on the System Panel connector on the motherboard (see p.1-20 of the manual for location of header and speaker pins) and check for any beep error codes (see beep code table on p.2-19).
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
They are two different sticks. They are seated in properly and everything. They even light up.
I will try the speaker test. It did not come with one, so I will have to get one. Thanks!
von
Antwort hinzufügen
Dreki wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 92
