Zum Hauptinhalt wechseln
The Insignia Flex 8 NS-P08A7100 is an 8 inch tablet with 16GB memory and the Android 6 operating system.
bypass lock screen on tablet
How do I bypass lock screen
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello! Starting with the tablet turned off, if you hold the power and volume up buttons for a while it should load into the recovery menu! From here you should have the option to factory reset it. That's most likely your best option, although you will use all the data currently on it.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Hi @ezzgen,
What about FRP lock due to reset?
Don't remember the pin most likely don't remember the account either
Cheers
von
That is true, atleast you can recover the username/password for a google account!
von
@ezzgen
True,
Hopefully they've thought of that then
Cheers
von
Antwort hinzufügen
Cathy Lowe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 642
