battery contact cable adhesive
I am rebuilding, having replaced the battery. In one of the later steps you heat the adhesive on the battery contact cable before gently removing. in the reverse - what adhesive should i use to fix the cable? it looks like its fixing to an aluminium patch - should i use thermal compound or regular hot glue or double sided tape?
thanks in advance
Ist dies eine gute Frage?
do you mean the flex cable from the battery with the gold contacts ?
von daniel
yes that is it... It looks like it had a copper like adhesive or possibly tape of some kind.
von SteveG
